Old 03-25-2011, 07:43 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question General ???? about the Drag Pak cars
Just for my own information when a DP vehicle is purchased where do you go to pick it up??? Is it delivered by a typical car hauler that delivers other new cars?? The dealer you ordered it thru, a distribution place , a select dealership, the factory, where??? Does this car run so that you can start it up & drive it around to like in front of a trailer to load it up or is it just a bunch of parts put together and you push it from one place to another??? What kind of trans do the stick & auto transmission cars have??? Read about them but they are not to clear about some of these area--I know it sounds kinda stupid but inquiring minds want to know---Thankx Comp
Old 03-25-2011, 08:58 PM   #2
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Default Re: General ???? about the Drag Pak cars
Mr Jeff should be able to fill you in......I believe it depends on the year.....
CBS is offline   Reply With Quote
Old 03-25-2011, 10:32 PM   #3
denbreeden
denbreeden's Avatar
Liked 61 Times in 26 Posts
You have to pick them up at Roush Racing. The 2009 and 2010's were not running cars, you had to pick them up in an enclosed trailer. No transmission and a boat trailer for the rear axle. 2011's are V-10 powered, complete running cars.
denbreeden is offline   Reply With Quote
Old 03-25-2011, 10:45 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
What rear end do the V-10 cars come with?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-25-2011, 11:10 PM   #5
denbreeden
denbreeden's Avatar
8 3/4 center section in a modified 9" housing.
Old 03-25-2011, 11:17 PM   #6
denbreeden
denbreeden's Avatar
http://www.mopar.com/assets/pdf/perf...spec_sheet.pdf
Here's the info on the 2011's.
Old 03-25-2011, 11:32 PM   #7
MPR
Liked 23 Times in 8 Posts
All 2011 Drag Paks come from the factory with a Strange Nine Inch rear axle assembly Mopar P/N P5155850. No Drag Paks came from the factory with an 8 3/4. 2009 Drag Paks had an independent rear suspension cradle with no diff and 2010s had a trailer axle for transportation purposes only. Several racers equipped their 2009 and 2010 Drag Paks with 8 3/4 or Strange/Dana 60 rear axle assemblies but the factory never installed any rear diff in a Drag Pak Challenger until 2011.
MPR is offline   Reply With Quote
Old 03-26-2011, 12:20 AM   #8
Ed Fernandez
Talking Re: General ???? about the Drag Pak cars
Thank you.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-26-2011, 12:47 AM   #9
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
Smile Re: General ???? about the Drag Pak cars
Hang on a second......Ed, you didnt know something about a Stocker? Glad my calander is near by
dragracer502 is offline   Reply With Quote
Old 03-26-2011, 02:20 AM   #10
Phillip marvetz
Phillip marvetz's Avatar
Well now, A strange 9 inch has a Mopar part number. That makes it a corprate assembly. Mopar's and Amc stocker's can now run a 9 inch. Your pretty smart Ed.
2009 V/SA Record Holder
