Old 03-23-2011, 08:07 PM   #1
art leong
Default Hole in throttle plate?
I have a .125 hole drilled in the throttle plate (throttle body) of my box manifold.
It idles aroud 2000 rpms. I thought it was needed due to the cams I'm running.
I put the individual throttle body manifold on and the car idles at 800 rpms so it isn't the cams.
The most I can get for vacuum with the box is 70 kpa, the ITB's idle at 50 kpa.
I want to close the hole up in the throttle plate.
What is the best way to do it?
Art Leong 2095 SS
Old 03-23-2011, 08:13 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Hole in throttle plate?
Art, if it idles down to 800, why do you need to plug holes in the throttle blades?
Ed Wright 4156 SS/JA
Old 03-23-2011, 08:28 PM   #3
art leong
This is the single throttle body, not the ITB's. The ITB's idle fine with no holes
I didn't put the hole in the throttle plate. I bought the caravan manifold with the throttle body on it.
Art Leong 2095 SS
Old 03-23-2011, 09:02 PM   #4
partsbob67
Liked 79 Times in 11 Posts
there is a kit from ford that has a bunch of plugs and a tool to install them. i have it at work. when i get back from vegas on the 29th i can send you some of the plugs if you would like.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-23-2011, 09:13 PM   #5
art leong
Okay Thanks. I'm going to try to get another throttle plate. But I'm not sure which throttle body it is. I was told it was 70mm but it's more like 62mm. But what can you expect from someone the modifies a DodgeCaravan manifold. LOL
Art Leong 2095 SS
Old 03-23-2011, 09:52 PM   #6
BillK
Liked 30 Times in 17 Posts
Art,
Anyone that is good with a TIG welder should be able to weld it shut for you. It will take loner to turn the welder on and put on a helmet than doing the actual welding.
Bill Koustenis
BillK is offline   Reply With Quote
