Old 03-17-2011, 09:28 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Front end specs
OK, I can't get in touch with the guy that usually does my work.
I have had a well known shop do a bump steer and toe steer modification to my 1986 Camaro I run in SS. It cam back to me with the frontend out of adjustment. (not too happy about that) It has some lamb repalcement for stock struts on the front end and the travel is limited. All stock man steering w/drag link dampener.... I have a local guy that has a nice machine that can align it. I just need some specs. Toe, C&C..what works? Any tricks or things I should be aware of?
E-mail me or PM me if you dont want to post it to the world.
Adger Smith
adgersperf@aol.com
903 794 7223 shop
903 824 4924 cell
Adger Smith (Former SS)
Old 03-17-2011, 09:42 PM   #2
Default Re: Front end specs
Adger, we run about 7-8 degrees of positive caster, about zero degrees of camber at around 2-3" above static ride height (to allow for attitude change under acceleration) and around 1//8" to 1/16" of toe in.
Old 03-18-2011, 02:03 AM   #3
Adger Smith
Is that on a Gen 3 strut front end?
Old 03-18-2011, 09:38 AM   #4
No Adger, that's on the two 1st gen 69's.
Really shouldn't matter, it keeps bump steer to a minimum, makes it go straight at speed, and keeps rolling resistance down. That's what makes the car work well and drive easy.
The only thing you'd want to check is how that camber setting effects your camber change through travel, to make sure it doesn't do something stupid.
Old 03-18-2011, 10:38 AM   #5
tj310
Stock settings work fine. As far as jacking up to set alignment, car should be setup sitting at the same attitude it goes through the traps. Our car is set at 3* positve caster 3/4* positive camber 1/8 * toe in. ...Thanx Trevor
Old 03-18-2011, 01:01 PM   #6
bert powell
Liked 34 Times in 12 Posts
Specs from a couple of top chassis builders: 0 camber, 1/16-1/8 toe in and all the caster you can get as long as even from side to side. All this is at ride height at speed.
bert powell is offline   Reply With Quote
Old 03-19-2011, 01:41 AM   #7
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
Adger you have a PM
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 03-19-2011, 08:45 AM   #8
Ed Wright
Ed Wright's Avatar
That is what I have always used.
Ed Wright 4156 SS/JA
Old 03-19-2011, 09:03 PM   #9
Adger Smith
With "all the Caster you can get"... how does a car handle when you get on the brakes -Hard- at the finish line to scrub off ET or drop the front spoiler to trip the beams. I've always thought a lot of caster (too much) causes steering problems when you are hard on the brakes.
Old 03-19-2011, 09:14 PM   #10
Ed Wright
Ed Wright's Avatar
I may not run fast enough for that to show up. LOL
