Old 03-01-2011, 05:57 PM   #1
dragginwagon
Default carb spacers
will an engine actually pull air through a plywood carb spacer??...
dragginwagon is offline   Reply With Quote
Old 03-01-2011, 05:58 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: carb spacers
plywood spacers have been in use for decades.
Old 03-01-2011, 08:33 PM   #3
House of Darts
Liked 20 Times in 15 Posts
The spacers are made of Baltic Birch plywood. The plywood has no voids many plys(its dense) and doesn't warp. It has a heat transfer less that phenolic resin. You can soak it in epoxy resin to make it super hard.
House of Darts is offline   Reply With Quote
Old 03-02-2011, 09:00 AM   #4
dragginwagon
a CNC router holds down material with vacuum sucked through a sheet of 3/4 inch MDF...vacuum pump is 7hp...
