Old 11-17-2010, 10:02 PM   #1
mike coates
mike coates's Avatar
Default Stock Carb Substitutes
I am looking for input on legal carbs for stock.
The engine specs list the carb numbers and sizes for each engine. If you run a specific combo, can you use the same type carb from another engine, as long as the size matches?
For example, I run a 70 340 with the AVS. There are a number of AVS carbs for the 383 or earlier 340s that have different carb numbers, but have the same measurements. Is it legal to run one of these in place of the correct 70 carb?
Also, anyone in IHRA, I run mine in Pure Stock, do you know if it would be legal to due this, if it is legal in regular stock.
Thanks for the input.
Mike Coates
Mike Coates
TBD
mike coates is offline   Reply With Quote
