Old 11-17-2010, 12:06 AM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default 5.7 Hemi
What bellhousing bolt pattern does the 5.7 Hemi use?
Old 11-17-2010, 12:15 AM   #2
Stewart Way
Liked 70 Times in 22 Posts
Default Re: 5.7 Hemi
The new Hemi has the small block engine bolt pattern but the starter is on the pass side. I just got a Quicktime bellhousing but opted for a driver side starter so I might be able to use 340-360 headers with some mods. It fits fine.
Stewart Way 2424 SS
Old 11-17-2010, 10:13 AM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: 5.7 Hemi
Did you know that a late model Ford racer was DQ'ed for having the starter on the wrong side from OEM? Dont remember if it was stock or S/S but thinking it was a S/S Mustang this year. It might be worth looking into to see if its 100% legal to move the starter if your building a stocker or S/S. I believe this happened in Div.1.
Old 11-17-2010, 10:39 AM   #4
Dwight Southerland
So that means they can use a small block 904 or 727?
Old 11-17-2010, 10:50 AM   #5
Ed Wright
Ed Wright's Avatar
Goin over to the dark side Dwight? lol
Ed Wright 4156 SS/JA
Old 11-17-2010, 11:39 AM   #6
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Be a maverick and hang a crashbox 833 behind it....
Yes all the DP motors are SB even the new 450HP viper motor is too, I know my DP came with a viper 6 speed.
Eric
Eric Merryfield 1883 STK
Old 11-17-2010, 12:05 PM   #7
Stewart Way
Dwight
727 or 904. I have been using a gutted 904 for mockup on my SSGT car but I'm going with a Gforce.
Stewart Way 2424 SS
Old 11-17-2010, 05:24 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
Yep X Tech,
That is the same thing I've been told about my V-6 Super Stocker. Correct side for the starter.
In SS/?X classes you can put the starter anywhere. In SS/DS (modified stock) I've been told the starter has to be locaterd in the origional location. I wouldn't be too quick to move it in Stock or SuperStock. Better be careful that could be a way to leave a race early.
Adger Smith (Former SS)
Old 11-17-2010, 09:05 PM   #9
Stewart Way
Guess I Better check with NHRA. Maybe on a GT car I can claim I kept the starter on the original side, or not?
Stewart Way 2424 SS
Old 11-17-2010, 09:20 PM   #10
Stewart Way
Did a little checking in my 2009 Drag Pak book and the cars came with a viper trans for the stick and a 904 case for the auto. Since the starter bolts to the trans with a 904, I think the correct side will be the drivers side. The viper is a little tougher to figure out. The photo I have shows the starter to be on the same side as the clutch fork but either the photo is reversed or the fork is on the passanger side. Anyone with a drag pak care to say whichside the starter is on?
Stewart Way 2424 SS
