Old 11-07-2010, 06:17 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default Hydraulic throwout bearing in SS
Anyone have good or bad thoughts or experiences on hydraulic TOB's in a clutchless SS car. I have used one in Lenco/bracket application but don't know of any in SS. Sure would be nice to not have all that linkage. With only needing it on the launch I don't see a problem. I think a positive stop would allow for a constant air gap setting.
Stewart Way 2424 SS
Old 11-07-2010, 06:44 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Hydraulic throwout bearing in SS
i was informed that i COULD NOT convert (by NHRA) from mechanical linkage to hydraulic in my rambler.
would have made my life easier...
can't tell ya about SS though..
Old 11-07-2010, 10:15 PM   #3
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Hydraulic throwout bearing in SS
The reason for that is that in Stock,certain individuals used a mechanism equivalent to a large Line Loc in the line between the clutch master cylinder and the throw out bearing, then a release button somewhere. Mashing down the clutch with the line loc closed held the clutch down even with no pedal pressure,and releasing it with the switch at the desired instant of launch. Since trans brakes are illegal in stock, why would this setup be any different? I agree that hydraulics would be far easier to install and engineer than mechanical linkage,but it's hard to get around the limitations of a mechanical clutch linkage that would prevent it from being anything but foot activated.
Old 11-08-2010, 01:46 AM   #4
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Not allowed in NHRA SS. Been there and done that. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 11-08-2010, 02:57 AM   #5
JP
JP's Avatar
Hydralic is stock in my car, still not allowed in SS?
JP is offline   Reply With Quote
Old 11-08-2010, 05:47 AM   #6
Tom keedle
Tom keedle's Avatar
i was told (by nhra) that it wasn't in the "spirit" of stock elim.
you can laugh now...
Old 11-08-2010, 06:06 AM   #7
Ed Carpenter
I would call your friendly neighborhood tech man first.
Ed Carpenter
Old 11-10-2010, 12:41 AM   #8
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Don't waste your time with the hydraulic linkage, unless an inconsistant reaction time is somethig you are not worried about! Hotter the fluid temp the R/T is faster, colder the fluid temp the R/T is slower. I believe the button boys found this out with the miracle AX delay box, I mean button having to keep it the same temp as possible every run to be consistant.
I have a hard enough time having a consistant R/T without having the car throw another variable at me for the R/T.
Take the time to build a good linkage and you will not regret it!
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 11-10-2010, 09:35 AM   #9
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
X2 what Brad said.
Mike Taylor3601
Old 11-11-2010, 10:43 AM   #10
Ed Wright
Ed Wright's Avatar
What are the stick '93/'02 GM F body cars using? They came hydraulic, but a lot of guys have trouble with that on modified street cars.
Ed Wright 4156 SS/JA
