Old 09-13-2010, 01:55 PM   #1
Earle Holt
Liked 4 Times in 1 Post
Default rod/piston assembly weight
Where do I find the minimum weight for a rod/piston assembly for my combo? Does the weight include rings and bearings?
Thanks,
Earle
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 09-13-2010, 02:04 PM   #2
Liked 1,952 Times in 439 Posts
Default Re: rod/piston assembly weight
I think it is in the accepted replacement parts list in the competition section. It includes rings, but not bearings, since you can easily remove the two bearing shells from most connecting rods, and also the bearings would have different weights depending on how far the rod journal has been ground undersize.
Old 09-14-2010, 01:30 AM   #3
Cam
Cam's Avatar
I think this is what you are looking for.
http://www.nhra.com/competition/pistons.aspx
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 09-14-2010, 07:04 AM   #4
Earle Holt
Thanks guys, I appreciate it. Looks like weight does not include bearings and rod bolts.
Old 09-14-2010, 09:27 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
It may not be clearly stated, but I think you will find that rod bolt weight is considered part of the rod weight. All that is important is the correct parts/part numbers and the correct assy. total weight.
Adger Smith (Former SS)
Old 09-14-2010, 09:52 AM   #6
Adger is correct, all rod fasteners are included, the total weight of the rod includes the fasteners, they put the rod nuts back on, or the bolts back in, before they weigh it. They only leave the bearing out, and for the reasons I gave.
Old 09-15-2010, 09:04 AM   #7
Earle Holt
Thanks everyone. I appreciate it.
Old 09-15-2010, 09:49 AM   #8
Adger Smith
Earle,
Another point that is clear as mud is the pin locks. You will find that "If" a piston is actually run press fit on the rod no locks are figured in the piston weight. If it is floated and pin locks are used they are considered part of the piston weight and are included in the total assy weight. Don't forget about them.
