Old 07-19-2010, 10:53 AM   #1
CJ Perry
CJ Perry's Avatar
Default which throttle stop?
As the title says...what throttle stop are yall running. We finished up our car just need a throttle stop. Thanks
CJ Perry
9931
PCA-1
CJ Perry is offline   Reply With Quote
Old 07-19-2010, 12:39 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: which throttle stop?
We run the Dedenbear TS6 which I (and many others) think is by far the most consistent and reliable one in the business. But there are limitations to it, and if you have a huge HP motor some people are finding you can't shut it down enough.
We, for example, with 900HP can't get the TS6 to go below 4000 RPM no matter what we do. That number works for us, but for others with bigger HP, they have to be on the stop for an hour and a half at 4K and they'd prefer something lower. So they end up using in a linkage stop and going down to, say 3600.
Whichever you choose, I strongly recommend that you choose an air stop. The ability to carefully control the speed of on, and more importantly off, the stop is crucial. You can come off the stop with less trauma with an air stop.
Hope this helps,
Chris
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 07-19-2010, 02:02 PM   #3
Joe Rich
Smile Re: which throttle stop?
I have used the dedenbear disc stop when they came out , when new it was deadly. after a while it started to drift , we sent it back to refresh and could not get it dead on. now we use the #1 stop and we like it.
Joe Rich 2195 SG
Joe Rich is offline   Reply With Quote
Old 07-19-2010, 02:51 PM   #4
Bill Baer
Well I run a Ron's fuel injection and censequently I have to shut the barrel valve to keep from flooding th motor with fuel so I use an in line throttle stop.|
if you choose to use an inline throttle stop you need be be sure that the pedal stop is a solid one or it will drive ya nuts!
Old 07-19-2010, 03:07 PM   #5
Bob Verwold
Bob Verwold's Avatar
Biondo inline air stop, works good for me.
Bob Verwold is offline   Reply With Quote
Old 07-20-2010, 03:57 AM   #6
Lou SG2340
It was 1 Stop for me. The plus for 1 Stop is Gary. He will spend as much time with you as necessary to answer all your questions. Also use air. You can not adj the opening & closing with elec.
Lou SG2340 is offline   Reply With Quote
Old 07-20-2010, 11:30 AM   #7
Bob Mendenhall
I use a Biondo inline air stop primarily because of a height issue with the bottom of the hood scoop. The #1 Stop that I used on my last car would not fit and still allow me to use a K&N air filter. The only thing that you have to be certain about is that the throttle linkage has a positive stop. The thing that I really like about the inline unit is that when the throttle re-opens it actuates the accelerator pumps, that insures that I don't have a temporary lean bog. I run the downpower rather low, normally around 4000 or less having the use of the accelerator pump helps. The only change I made to the Biondo was to open the air valve and use individual bleeds (On and off) to the throttle stop.
Bob
No \"Home\" page, just an e-mail address
Bob Mendenhall is offline   Reply With Quote
Old 07-28-2010, 11:52 PM   #8
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
TS6 here. I am one of those who cannot get the RPM down as much as I would like. I have 1050HP and am on the stop for 4.7-4.9 to run S/ST. I am only able to get it s=down to 4000ish but it seems to work for me. Unfortunately the motor had an issue with the cam and is down righ tnow waiting for a cam core blank.
sst7250 is offline   Reply With Quote
Old 07-29-2010, 07:58 AM   #9
TS310C
We use both a #1 stop on one car and a Dedenbear TS5 on the other car. Both are air stops and both work well. No problem at all getting the RPM's down. I have my car set at about 3700 right now and could go lower.
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
Old 08-05-2010, 08:56 AM   #10
chevy620
Banned
Number 1 Stop. End of story.
If you ever have a question, need technical help or need a part, Gary Heuer will be the best service you have ever seen.
Wouldn't bother running a Super Class without his products.
chevy620 is offline   Reply With Quote
