Old 07-19-2010, 12:26 AM   #1
Jason Fuller
Guest
Posts: n/a
Default I found a Stock Eliminator car in the Blueprint/Car Classifications but..
The car in question is the 2003 Pontiac Boneville SSEi.
There is no runner volumes on the head numbers,no replacement pistons and or weights, and the difference in rod length from 2002-2003 is an astounding .300"....Well just under....
After the frustration of this I came here and wanted to ask you if your combo that you run, or any other running combo does not have a documented runner volume listed and or bob weight unlisted.
This should be interesting...Thank
you in advance.
Old 07-19-2010, 12:52 AM   #2
bill dedman
Liked 6 Times in 4 Posts
Default Re: I found a Stock Eliminator car in the Blueprint/Car Classifications but..
Are the newer rods longer???
Bill
bill dedman is offline   Reply With Quote
Old 07-19-2010, 03:46 AM   #3
Jason Fuller
Guest
Posts: n/a
No...the years of 2000-2002 are longer..the 2003 are almost .300" shorter..I've yet to see what this does on my engine analysis software...thay maybe a *** load lighter...but no info is given....thats why I'm frustrated...I go through a lot of combos to see whats happening....this one was the most frustrating....
Old 07-19-2010, 07:10 AM   #4
art leong
Some times there are typos in NHRA's book. Check the real stock parts and see if it is.
If no piston manufacturer has submitted a piston, there will be no replacement pistons. You have to use the ones that are made by the manufacturer. As far a runner volumes goes they have never poured that particular combo so there aren't any numbers yet.
Art Leong 2095 SS
Old 07-19-2010, 02:47 PM   #5
Pat Cook
So, if your heads are the first to get poured then that number goes into the classification guide?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 07-19-2010, 03:14 PM   #6
Jason Fuller
Guest
Posts: n/a
Sweet! Hey Charlie, break out the epoxy for the flashing seams on the casting and hand me some of that there acid!
Old 07-19-2010, 04:57 PM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Jason our 6cly V/SA engine has no #'s if dad didn't have the "good motor" bolted together on the stand I would take it to have poored
Old 07-19-2010, 06:18 PM   #8
Jason Fuller
Guest
Posts: n/a
Wow! I thought there were some combos out there running down the strip without numbers..
Thanks Greg..
