Old 06-02-2010, 02:16 PM   #1
benningtonr
Default Can I get some pictures please
I am looking for pictures of Alf Wiebe's setup.
I have been trying to purchase it but cannot,
So I would like some detailed picture so that I can make my own. Or maybe just some pictures of what works for your Chevelle. I am a small time bracket racer that is having trouble hooking up/
Thanks for your time.
Ron
benningtonr is offline   Reply With Quote
Old 06-02-2010, 06:39 PM   #2
72Malibu
72Malibu's Avatar
Default Re: Can I get some pictures please
I'm using a Moser 12 bolt, the ears are raised on it 1.5" above a GM 12 bolt. I am using all stock location mounting points in the rear, Moog oem replacement springs, QA1 single adjustable shocks, www.hrpartsnstuff.com bolt-on antiroll bar. I am also using polygraphite bushings in my front, stock, upper and lower control arms, Santhuff springs and shocks also. Puttin it all to the ground with Hoosier 30x9x15 radial slicks.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 06-02-2010, 07:21 PM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
I SEE ONE FORSALE ON RACING JUNK UNDER SUSPENTION
http://www.racingjunk.com/category/1...2-a-body-.html
Ron
MEXJOE is offline   Reply With Quote
Old 06-02-2010, 09:01 PM   #4
Jeff Lee
Jeff Lee's Avatar
Wow, 1st time I've actually seen Wiebes work. That's some engineering involved there. Now I see why those A-bodies with his suspension work as well as they do.
Jeff Lee 7494 D/S '70 AMX
Old 06-03-2010, 09:52 AM   #5
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Does anybody know if this is the original setup or the latest version?
Old 06-03-2010, 10:21 AM   #6
Advertised as the latest.
Old 06-03-2010, 10:26 AM   #7
67ss
But it's not. Will work fine for a bracket car though.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
Old 06-03-2010, 01:01 PM   #8
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: Can I get some pictures please
Was this set up legal at one time? What has changed? I don't see how this set up would be legal. But, I do not race this style car.
Robert Simpson is offline   Reply With Quote
Old 06-03-2010, 05:12 PM   #9
Jeff Lee
Jeff Lee's Avatar
I'm thinking there is a welded piece for that small diameter upright which would be a problem?
Old 06-03-2010, 09:36 PM   #10
67ss
Alf's system is 100% legal. I don't know the specifics behind all the rules controversy as I am just a bracket racer, but everything was ironed out and it is approved by NHRA, and I know of 1 car for sure that also runs IHRA events using his system. I do know the newer system mounts directly to the stock LCA mount. No welding of any kind involved with either the earlier or latest system.
Chad Harris
67 Chevelle SS
