Old 04-27-2010, 08:10 AM   #1
Clint Miller
Question IHRA Crate Motor Classification
When you are determining the base class for a crate motor car, which shipping weight do you use....lowest, highest, your choice? In particular, I am trying to determine the class for a 97 Camaro with the 350/330/340 Vortec motor.
Clint Miller is offline   Reply With Quote
Old 04-27-2010, 10:09 AM   #2
Chris1529
Liked 70 Times in 29 Posts
Default Re: IHRA Crate Motor Classification
I think you have to use the heaviest V-8 shipping weight for the body style you claim.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-27-2010, 10:46 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: IHRA Crate Motor Classification
Actually, I believe if you run a small block, use the heaviest small block shipping weight. Run a big block, use the heaviest big block weight. Or use the heaviest weight available if the car was only available with a 6 cyl. or small block.
Old 04-28-2010, 09:37 PM   #4
Clint Miller
Thanks guys!
Old 04-29-2010, 12:34 AM   #5
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
It will fit G @3230lbs if my math is correct.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-29-2010, 03:33 PM   #6
Clint Miller
I came up with 9.59 lbs/hp (3262 lbs / 340 hp) which should make it a natural H/CM. But it is entirely possible that I am figuring it wrong.
