Old 04-12-2010, 09:26 AM   #1
dean ribeiro
Liked 239 Times in 79 Posts
Default rear gear manufacturer success?
just curious as to which manufacturer of rear gears are people using and with what success?
I had the rear gears fail (shredded the teeth) at ATCO this weekend and need to replace them. In the past we have gotten 250-300 runs out of a set of gears, but this no longer seems to be the case? anyone have a manufacturer that they would recommend?
We are typically careful to set up the gears correctly, however, I recently purchased this car and have no idea how many runs were on the gear set.
any help would be gretaly appreciated, Thank You!
Dean
dean ribeiro is online now   Reply With Quote
Old 04-12-2010, 09:30 AM   #2
Bobby Brannon
Liked 104 Times in 35 Posts
Default Re: rear gear manufacturer success?
Richmond "PRO" Gear
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
Old 04-12-2010, 10:30 AM   #3
Jim Kaekel
Liked 536 Times in 110 Posts
X2 on the Richmond pro gear. I ran street gears for many years, but wound up switching to the pro gears after tearing up a couple of street gear sets. This was running low 11's in a 3800 lb. car.
Jim Kaekel 3836 STK
Old 04-12-2010, 11:14 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
Richmond Pro Gears, in my experience, will last very well. With an auto trans foot & brake will last for many seasons. With trans brake and heavier cars, higher power, still last for 100's of runs. (of course, this is a general rule)
Larry Woodfin 471W
Old 04-12-2010, 06:28 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
The Pro gears are holding up, but I've had several customers experiance your type of failure with the street gears..........This has been going on for 3-4 years now. 9",12bolt ,even Dana60 ..........Tom
Old 04-12-2010, 07:14 PM   #6
John Kelley
Does anyone here use cryo or the mikronite process on their rear end gears ?
And does it help in the lifespan of gears ?
John Kelley is offline   Reply With Quote
Old 04-12-2010, 08:07 PM   #7
nssracer
Liked 207 Times in 23 Posts
Jim Bailey just did cryo on my gears. He does great work.
Old 04-12-2010, 08:24 PM   #8
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
Thumbs up Re: rear gear manufacturer success?
Dean, Precision Gear pro gears, 350 plus runs with a stick!
http://www.reiderracing.com/
Sam
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 04-12-2010, 09:51 PM   #9
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Regardless of who you choose to get your gears from, ship 'em off to Jim Bailey at FINISHED (finishedracing.com). REM & Cryo treatments together make them last longer *and* roll more freely, which I hadn't considered! Found a little ET in my car. The Pro Stock and Comp guys have learned the secret. It's actually pretty cheap, too.
Old 04-13-2010, 06:22 AM   #10
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Send any gear set, street or pro to Jim Bailey and have them Cryoed and rem finished. They will last longer, turn more freely and the cost is minimal. Turn around time is fast. Go to http://www.finishedracing.com.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
