Old 03-23-2010, 08:17 PM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Air cleaner in Stock Class
Learning as I go, I had another question - the NHRA rulebook states that an air cleaner, if used, must be OEM automotive or retain OEM configuration. Big-block Chevy Super Sport's came from the factory with an open-element air cleaner. Does this mean I can use one of these on another GM product in Stock Class, or am I stuck with the OEM air cleaner that came on the car? And what about a K&N, which has the OEM configuration? Thanks again for your suggestions!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-23-2010, 10:58 PM   #2
Jody Lang
Liked 89 Times in 28 Posts
Default Re: Air cleaner in Stock Class
K&N is fine.
Jody Lang is offline   Reply With Quote
Old 03-24-2010, 12:32 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: Air cleaner in Stock Class
Just not the K&N with the filter top.
Old 03-24-2010, 03:02 AM   #4
GTX JOHN
Liked 2,487 Times in 698 Posts
Really. we have run filter top on dusty tracks...not legal?
Old 03-24-2010, 07:49 AM   #5
tj310
We went through tech at Indy Open in the fall with filter style top and no comments were made ...pretty easy to take off if they don't like it...we leave it off every once in a while doesn't seem to make any difference to speed. ...Thanx Trevor
Old 03-24-2010, 11:15 AM   #6
Lew Silverman
Thanks for the input! I'm going to try with and without to see if there are any disadvantages to using the high-flow element. I'm hoping it will smooth out the airflow somewhat with the Q-jet.
Lew Silverman #2070
Old 03-24-2010, 11:34 AM   #7
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
X2, in D3, they dont like the K&N filter top....
Wade
Old 03-24-2010, 12:12 PM   #8
SSDiv6
The K&N Filter top is just hype. It does not offer any HP improvement at all. Just run a Moroso lower and top base with a racing air filter element from Wix and you will see a lot more performance.
http://www.wixfilters.com/filterlookup/racing.asp#air
The K&N Filter top will disrupt the airflow to the carburetor.
Old 03-24-2010, 01:44 PM   #9
mopar jeff
mopar jeff's Avatar
X2 on this one. We did back to back dyno test, and actually lost horsepower with the filter top. What a marketing joke.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 03-24-2010, 04:48 PM   #10
Isaac Zane
Isaac Zane's Avatar
Liked 50 Times in 14 Posts
We have our engine pic in the National Dragster several years ago and got a call from Tech and were told to take that K&N Filter Top off!!! Well, we did.....
Isaac Zane STK 1237
J/SA Buick Apollo
Patriot Guard Rider DOOF 43
Isaac Zane is offline   Reply With Quote
