Liked 129 Times in 59 Posts
Learning as I go, I had another question - the NHRA rulebook states that an air cleaner, if used, must be OEM automotive or retain OEM configuration. Big-block Chevy Super Sport's came from the factory with an open-element air cleaner. Does this mean I can use one of these on another GM product in Stock Class, or am I stuck with the OEM air cleaner that came on the car? And what about a K&N, which has the OEM configuration? Thanks again for your suggestions!
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 92 Times in 29 Posts
K&N is fine.
Liked 5 Times in 3 Posts
Just not the K&N with the filter top.
Really. we have run filter top on dusty tracks...not legal?
We went through tech at Indy Open in the fall with filter style top and no comments were made ...pretty easy to take off if they don't like it...we leave it off every once in a while doesn't seem to make any difference to speed. ...Thanx Trevor
Thanks for the input! I'm going to try with and without to see if there are any disadvantages to using the high-flow element. I'm hoping it will smooth out the airflow somewhat with the Q-jet.
Liked 3 Times in 1 Post
The K&N Filter top is just hype. It does not offer any HP improvement at all. Just run a Moroso lower and top base with a racing air filter element from Wix and you will see a lot more performance.
http://www.wixfilters.com/filterlookup/racing.asp#air The K&N Filter top will disrupt the airflow to the carburetor. |
#9 | |
Jeff Interlicchia 7077 D/SA 1998 Pontiac Firebird LT1 J707 E/T 1966 Dodge Coronet 500 |
Liked 50 Times in 14 Posts
We have our engine pic in the National Dragster several years ago and got a call from Tech and were told to take that K&N Filter Top off!!! Well, we did.....
Isaac Zane STK 1237 J/SA Buick Apollo Patriot Guard Rider DOOF 43 |
