Old 01-26-2010, 03:34 PM   #1
John Lang
Liked 6 Times in 2 Posts
Cool Decals !
Anybody have a good way to remove Decals from a race car ! Any help will be appreciated !,,,,,,,,,John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 01-26-2010, 03:41 PM   #2
W J
Default Re: Decals !
Adhesive backed? A heat gun, or elec hairdryer. Should peel right off. Then use "Goo-Gone" to remove any remaining residue. Goo-Gone is a citrus-based household solvent that will not affect automotive finishes. WJ
Old 01-26-2010, 03:41 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Decals !
Oh yeah, heat them up with a hair dryer, slowly peal them off, then use WD40 or CRC and a clean towel to remove the goo left behind. (old school). Jim
Old 01-26-2010, 04:55 PM   #4
Jim Kaekel
Liked 535 Times in 110 Posts
Hair dryer works great for me too. Be sure car has been sitting in a warm garage and sheet metal is room temperature, helps prevent pulling decals along with the paint.
Jim Kaekel 3836 STK
Old 01-26-2010, 05:24 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Heat gun or CRC work good........Found a product called Goo Gone that works real good on some of the more stubborn ones,usually the laminated type ,it's citrus based,and dosnt hurt the paint. .......Tom..........OOPS,I did'nt see your post WJ.
Old 01-26-2010, 06:11 PM   #6
W J
How about removal of the old style decals? The ones that we used to put into a pan of lukewarm water and slide them off the paper backing, then apply them and squeeqe out the water bubbles....I know on glass it's a simple deal w/razor blade for removal, but what about removal of this style decal off lower (painted surface) body panels, etc.??? Any "senior racer" tricks for these??? WJ
Old 01-26-2010, 06:49 PM   #7
Dion Hildebrandt
Dion Hildebrandt's Avatar
In the autobody industry we use a rotary rubber eraser tool for large decals, if used carefully no paint lifting and a just a little polish on the paint for the rubber residue
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 01-27-2010, 02:52 PM   #8
John Lang
Thanks All,,,,,,,,,,Will try your idea's, and I'll let you know !..........John
Old 01-27-2010, 03:17 PM   #9
Bob Verwold
Bob Verwold's Avatar
Wasn't that back before paint.........couldn't help it
Bob Verwold is offline   Reply With Quote
Old 01-27-2010, 07:09 PM   #10
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Any autobody shop should have those, some people call them plastic razor blades. Use a heat gun to get the glue good and pliable, than use the 'razor blade' to scrape the sticker off if necessary. Goo Gone like mentioned above is good for the residue. Easiest possible way to do the job.
2002 Division 6 High School Champion
2007 Division 6 Pro Champion
2007 Division 6 National Open Series Stock/Super Stock Champion
Sean Kennedy is offline   Reply With Quote
