Ok....I didnt like the cooler we had so it went back....it was too big and too heavy.
I completley forgot to buy a replacment for it. I need something SMALL , and LIGHT, Paul at TA said they make (but he didnt know who) a smallish like 4 in thick maybe 7 wide cooler with 2 fans.....anyone know of anything like this ? Air flow will be OK where its going to mount, but if I can get one this size I can mount it in the nose in the lower grille... Otherwise it will be in front of the driver front inner fender below the engine compt apron above the spash apron I can if need be direct some airflow from the lower grille. Its a 904 and the car will be doing pretty hot laps during testing/changeup there will be a tranny temp sender to the Racepak so Ill know where Im at.... Any suggestions on something small but capable ? I cant believe I forgot this, I was making a list of fittings to go down to Summit on Sunday and well it became glaringly evident I had nothing to connect the other end to.... |
