Old 11-23-2009, 03:20 PM   #1
lbiexit63
Default 2 step question?
Can anyone help explain to a newbie what the 2 step is and how it works? Thanks
lbiexit63 is offline   Reply With Quote
Old 11-23-2009, 06:34 PM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: 2 step question?
it is used on the starting line...when the button is hit it drops the rev limiter to a lower RPM. that lets you set on the starting line wide open then when the button is released it switches back to high end rev limiter.
Old 11-24-2009, 12:37 AM   #3
mopar jeff
mopar jeff's Avatar
Default Re: 2 step question?
Can anyone tell me if the MSD 2 step with the dial in launch control is legal in stock. Or does it have to be only controlled by plug in chips?
mopar jeff is offline   Reply With Quote
Old 11-24-2009, 01:15 AM   #4
Jeff Lee
Jeff Lee's Avatar
Any way of adjusting is allowable. The rule states it must be out of the reach of the driver.
Jeff Lee 7494 D/S '70 AMX
Old 11-24-2009, 09:54 AM   #5
mopar jeff
mopar jeff's Avatar
I guess technically it's a 3 step. Is that still acceptable?
Old 11-24-2009, 08:43 PM   #6
greg fulk
greg fulk's Avatar
yep
Old 11-25-2009, 12:45 PM   #7
mopar jeff
mopar jeff's Avatar
Originally Posted by greg fulk View Post
yep
Good to know, but you are not setting me up are you?
Old 11-25-2009, 03:30 PM   #8
Pat Cook
Smile Re: 2 step question?
I have mine hooked to the factory brake light switch. Work very well connected there, except when I redlight.....
Pat Cook is offline   Reply With Quote
Old 11-25-2009, 04:52 PM   #9
greg fulk
greg fulk's Avatar
Talking Re: 2 step question?
I the idea for a 3-step is 1 for the water box. 1 for the starting line & 1 for OH! Shxx!!!!
Old 11-25-2009, 08:52 PM   #10
Jeremy K
I have a question about using the two step for a burnout limit in stock eliminator. If I have my linelock button on the shifter, am I not allowed to hook the two step up to this. I think I know what the answer will be since the rule book says two step must be foot activated, but I just wanted to see what I could do with it. I don't "use" it to do the burnout, but it's nice just in case my foot gets heavy. Thanks
Jeremy K is offline   Reply With Quote
