Old 07-30-2009, 12:50 AM   #1
JustinGallantRacing
Default Stick car Question?
Hey guys, got a quick question bout tire pressure.
My mustang weighs 2995 with me in it, I run a 26x10x15 Et Drag, Mild 302, Stock T-5 tranny, ford HD clutch, 8.8 rear with 4.30 gears.
Well the car seems to hook pretty decent but im worried Im not running enough tire pressure. I run them right aorund the 9 lbs mark and they seem to squish right down to the rim. I got one guy tellin me not to worry thats the way they work, and then a couple tellin me to run them at 11-12 im stumped!
JustinGallantRacing is offline   Reply With Quote
Old 07-30-2009, 01:27 AM   #2
CJohnson
CJohnson's Avatar
Default Re: Stick car Question?
Justin,
My dad always told me to keep raising the pressure till your 60's go down or you start to spin.
CJohnson is offline   Reply With Quote
Old 07-30-2009, 09:08 AM   #3
Harry 6674
Are you asking if 9lbs. is unsafe or will your car pick up with more pressure? Only experimentation will answer the last question. I've went as low as 6lbs in some tires before.
Harry 6674 is offline   Reply With Quote
Old 07-30-2009, 09:30 AM   #4
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
I have the same basic combo, but I'm making a more HP than yourself. I have always ran 12lbs of pressure on a set of brand new slicks, and as they got older, I went down to 11 and as much as 10.5lbs. If you go any lower than that your car will be walking around on the big end!!! Also you will be bogging the engine alot with to little air in the tires. Those little motors dont recover from a bad bogg!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 07-30-2009, 10:46 AM   #5
Chris1529
Liked 70 Times in 29 Posts
I agree, put more in until you 60 starts to go away. with that tire and my automatic, I ran up to 16 lbs.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
