Old 06-15-2009, 08:52 PM   #1
njk53
Default Another Line Lock Question
What would be the cause of a line lock not holding the car properly? When I set it, you can feel the solenoid click and engage the front brakes but, when you do a burn out it doesn't hold the car in place like it should. The line lock solenoid is a Biondo w/ a Hurst Switch. I was told to check for air in the lines which I will do. If it isn't air in the lines what other things should I check?
Nelson Kowal
Stock 345
Old 06-15-2009, 10:46 PM   #2
larry dowty
Liked 11 Times in 4 Posts
Default Re: Another Line Lock Question
make sure you have it going the right direction?
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 06-16-2009, 05:01 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Hold the switch, and pump the brakes a couple of times....
Old 06-16-2009, 07:46 PM   #4
njk53
Larry:
Do you mean direction of flow? Also, is it common that you have to pump the brakes a couple of time before you set the switch?? Someone else suggested the same thing.
Nelson Kowal
Stock 345
Old 06-16-2009, 08:14 PM   #5
larry dowty
yes they are directional, i know from experience i just had the exact problem with my new stocker and it was the dork that built the car LOL turned it around and the brakes work perfect
larry dowty 6388 SS
Old 06-16-2009, 10:56 PM   #6
Liked 5,120 Times in 1,951 Posts
Those things are rebuildable. Unscrew the brass part from the coil portion. Pull the piston out. There is a little seal that covers the orifice in the middle. Check the condition of the seal ,and that it's not pushed back too far.
Call Sal and see if he'll sell you a kit.
Old 06-17-2009, 09:28 AM   #7
Harry 6674
Thats where a brake pressure guage comes in handy. Hold the button and pump the brakes to build pressure. Same pressure every time. Also make sure your not sliding your front tires.
Harry 6674 is offline   Reply With Quote
Old 06-17-2009, 04:53 PM   #8
GTO/GN
GTO/GN's Avatar
Does the line lock solenoid allow pressure to pass through it in one direction? Cause the advise being given here is to " hold the button and pump the brakes"... All these years I've been putting the car in netrual, pumping the pedal then holding the pedal hard, then pressing the button.. My line locks have always held the car without any problems. I don't think after all these years I would change my routine, but was just wondering..
GTO/GN is offline   Reply With Quote
Old 06-17-2009, 08:15 PM   #9
njk53
The line lock unit is new. I will check the direction of flow tomorrow. I will alos try pumping the brakes. Thanks to all for the suggestions.
Nelson Kowal
Stock 345
Old 06-18-2009, 06:25 AM   #10
rallye bob
rallye bob's Avatar
I have a Hurst line lock and yes it is like a one way valve when the button is on.....
