Old 05-06-2009, 07:35 PM   #1
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Question Power valves and Throttle Stops
Does anyone use power valves in their throttle-stop carb? Is there a good reason to not use one? I have a problem, when the carb is jetted for max MPH, it doesn't come up on the brake cleanly on the starting line, even with small squirters. Any advice would be appreciated.
reknapp52 is offline   Reply With Quote
Old 05-07-2009, 09:15 AM   #2
Lou SG2340
Default Re: Power valves and Throttle Stops
I am not a carb expert but I have never run a power valve to throttle stop race. What size motor & carb are you using, does it have air bleeds that you can change? Mine is a 565 with a 1050 dominator. I jet it for mph & have to richen up the mid range air bleed for the stop. I use 42 or 45 squitters.
Lou SG2340 is offline   Reply With Quote
Old 05-09-2009, 09:26 AM   #3
Bart Nelson
Call me I will be able to help with some of your questions!
Bart Nelson
Bart's Dominator Service 281.924.2759.
Bart Nelson is offline   Reply With Quote
