What do you guys run? I set mine up and I can't hardly stop the car. The pedal is very hard and you have to stand on it to stop the car?
Thanks, Justen |
Liked 216 Times in 77 Posts
Did you repositon where the rod attaches to the pedal to get the correct pedal ratio? Billingsley racing recomends the hole be 1 inch above the factory riviot that the stock rod attaches to. This is how I did mine and its been great.
I did that on a 77 Firebird. Rock solid until I moved the rod up 1 inch to the next hole.
Next time wave all of your fingers at me. |
Liked 883 Times in 237 Posts
The stock hole only provides about 4to1 pedal ratio. ....Moving about 1" to 1 1/4" inches gives about 6, 6 1/2 to 1 ratio. ......Tom
I moved it up 1 inch and then moved it back 1/2 inch because the angle looked way off on the pushrod.
