Old 01-15-2009, 12:30 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default VP & Sunoco Race Fuel Cross Reference
Does anyone have a cross reference for VP racing fuels.
I assume Sunoco Purple (Standard) is the cross equivalent for C11?
Also, does anyone know which Rocket Race Fuel is equivalent C11?
What changes are usually needed to go from VP C14 to VP C11 and how much of a power difference is there for those who have tested these fuels?
Thanks
N/A
mannymen is offline   Reply With Quote
Old 01-15-2009, 02:44 PM   #2
FED 387
Liked 332 Times in 180 Posts
Exclamation Re: VP & Sunoco Race Fuel Cross Reference
Go to a website for WHITFIELD oil company--they have the more popular brands of race fuels in a chart so you can compare fuel to fuel from Sunoco to Rockett etc. Hope this helps ---Comp 387
Old 01-15-2009, 03:44 PM   #3
mannymen
Smile Re: VP & Sunoco Race Fuel Cross Reference
Found the chart. Thanks! Per VP, the rep mentioned that VP110 was similar to VP C-11, but it wouldn't pass fuel testing for the NHRA.
http://www.whitfieldoil.com/download...RENCECHART.pdf
N/A
Old 01-15-2009, 05:14 PM   #4
John Mason
Talking Re: VP & Sunoco Race Fuel Cross Reference
VP110 won't pass the $$$$$$ test. It's about 1/2 the price of C11. $5.00/gallon race gas? Can't have that!
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 01-15-2009, 06:05 PM   #5
Tracy Robbins
Liked 25 Times in 11 Posts
Default Re: VP & Sunoco Race Fuel Cross Reference
Rockett 111 would be equivalent to C-11. Lee Nylander @ Rockett is a wealth of knowlege. He answers their tech line check out www.rockettbrand.com for an 800 number.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 01-15-2009, 09:41 PM   #6
mannymen
I dyno'd with C14 (What was available at the time) in an SS 427 Alum headed motor, so would I have to richen the mixture to go to C11, Rocket 111 or Sunoco Purple? Not going back to the dyno anytime soon to test fuels. I assume I can get an idea on what to do by viewing my EGT temps after a run?
N/A
Old 01-15-2009, 10:03 PM   #7
Bub Whitaker
curious, did you optimize timing and jet w/ C14? which burns slower than C11? If so than you would have to run more jet and less timing to achieve the same burn...make sence???
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 01-15-2009, 10:30 PM   #8
mannymen
Makes sense. We optimized the timing and jetting with C-14
Thanks!
N/A
