Old 08-25-2008, 03:51 PM   #1
gearjammer
gearjammer's Avatar
Send a message via AIM to gearjammer Send a message via MSN to gearjammer
Question Tire Pressure
While my chassis is not legal for Stock Eliminator I am building it somewhat by S/E design and I'm having an initial traction problem. I'm being told to run no more tire pressure than 15 PSI in the Radial Slick and I'm wondering what you folks run for those of you that run this type of tire.
I am running a 30x9 MT ET Drag Radial mounted on a 10" wheel with 19 PSI
Caltrac's with 1/4 turn preload w/ drivers weight
Rancho 9000 shocks set on #4
Calvert split mono leaf springs
Anti roll bar (zero preload)
AFCO low friction ball joints & bushings
Moroso Trick Springs
Lakewood 90/10 shocks (8" of travel)
Thanks in advance for your help
Phil
Phil
JPR Motorsports
1972 Nova Street Strip Project
gearjammer is offline   Reply With Quote
Old 08-25-2008, 06:11 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Tire Pressure
What are you running for a driveline?
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 08-25-2008, 06:50 PM   #3
gearjammer
gearjammer's Avatar
http://jprmotorsports.blogspot.com/ Link to the build up of the car
9" w/ 35 spline axles, "N" case, spool
Hutch built Glide
460 CI BBC (iron heads) street engine
Phil
JPR Motorsports
Old 08-25-2008, 07:10 PM   #4
Bob Gullett
In my wife's stocker with the 305 we run 22-25 psi with the 9x30 radial with no traction issues. How much horsepower do you figure you have? In my Nova with the Cal tracs with the split leaf I changed from the Ranchos to a good double adjustable shock. I don't run a radial slick as I run stick in the car. They were not cheap but it made a big difference on traction.
68 Chevy11 327 F/S
Old 08-25-2008, 07:35 PM   #5
Joe DeMarzo
Liked 121 Times in 11 Posts
In my B/SA car, 70 Nova. 402/375 I run 24 lbs in the Hoosier radial. If you run less air you may spin tire due to making it oblong. Have a friend watch your car launch for feedback. If your suspension is right, no binding, no reason you can not run at least 20lbs. Check front end travel, rear seperation, converter flash, PM if you have any other questions.
Good luck
Joe DeMarzo 1317 STK
Old 08-25-2008, 07:47 PM   #6
gearjammer
gearjammer's Avatar
Thank you very much for your replies
By the way I have 550 hp
I know my converter is tight and a little smaller than what I think I need. it is a 8" 4500 ATI converter, my cam specs are 636/595 & 256/266
Phil
JPR Motorsports
Old 08-25-2008, 07:55 PM   #7
gearjammer
gearjammer's Avatar
Mr. DeMarzo
I will be sending you a PM this evening
Thanks again
Phil
JPR Motorsports
