Liked 75 Times in 29 Posts
Hi Guys
WE broke a rear axle (strange) at the PRP points meet this weekend. We are replacing both axles and the spool. Anybody have any preferences between strange, moser, and mark williams? We had probably 500 runs on this pair (8 year old 12-bolt chevy rear with a trans brake). Tom Sheehan GT/IA 1046 |
Liked 1,914 Times in 429 Posts
Thomas, the best stuff is the big Mark Williams. If you have a 3.250" bore differential case (comes in a station wagon or in the good aftermarket housing) Mark Williams has some really stout pieces.
Alan Roehrich 212A G/S |
Liked 24 Times in 13 Posts
I have been using the same Hi Torq 35 spline Mark Williams for 10 years.No problems.
There in a 1979 Camaro I / Stocker.3470 lbs with me in it and a four speed. |
bought mark williams 35 spline 12 bolt. in 1990...1000 passes later still like new with big block stick camaro..
Liked 20 Times in 15 Posts
Mark Williams.
Sounds to me like we have the best set in our car too... There Mark Williams
Liked 70 Times in 29 Posts
probably should put a Dana 60 in your car Tom.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
I never broke a Moser
Liked 57 Times in 33 Posts
I've broke atleast 15 rear ends in my race car. What would break is the caps on the rear olding the ring gear in and move the ring gear out of the pinion, in turn breaking the pinion. What im getting at is out of all of the breakage, its never hurt a 31 sline moser axle. Thats pretty damn tuff if you ask me.
Duane
Duane Eiskant 1354 Stock/Super Stock |
I like my Tom's axles and spool.....one broken axle in 2700+ runs, after I did a stupid thing swapping the axles side to side during a hurried up gear change.....
www.tomsdifferentials.com Only other choice would be the M/W setup, but those are matched splines that don't interchange with anyone else's. Tom also offers the alloy cap kit for 12-bolts, highly recommended!!!! |
