Old 04-29-2008, 10:35 AM   #1
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Default Front tires
What advantages are 28" front tire vs a 26" besides longer rollout and reduced rpm? Ride height and fender clearance are two problems with 28" that I'd like to get away from.
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 04-29-2008, 12:39 PM   #2
Bobby Lundholm
Liked 128 Times in 50 Posts
Default Re: Front tires
Goodyear has a 27" available. That is what I have on my car right now.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 04-29-2008, 05:55 PM   #3
Gary Smith
Gary Smith's Avatar
Bobby, I either have 27 or 28" Hoosiers right now (can't remember what they are, will check tonight). Just I've seen several stockers using 26 and in some cases, 24". Just curious if there's a performance gain or hit with shorter tires.
Gary Smith
Old 04-29-2008, 07:18 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
Gary, most guys running the short 24" or 26" tires are using them to help reaction time. The shorter tires also will hurt 60ft times somewhat.
I run the 26" Hoosiers and i need all the help on reaction time i can get and sometimes it wouldn't matter what rollout tire i have!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 05-04-2008, 01:29 PM   #5
NovaMan
NovaMan's Avatar
Depending on your frame and suspension, you may be able to get more front end rise with taller front tires.
I don't know what you race, but consider my Nova (or any 68-72 Nova or 67-69 Camaro): the bumpstop is between the subframe and the bottom of the upper control arm. So if I can get the upper control arm higher up, I'll have more front end rise before it yanks the tires. One way to do that is just to lower the front end, but to keep the same distance between my frame and the ground, I'd have to put taller tires on it. Right now I can barely get my jack under the crossmember, so I plan on changing springs and trying some taller tires.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
