Old 11-20-2008, 01:06 PM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Race Pumps mechanical fuel pump
I like the Racepump theory and packaging, but I just run a Holley Street/Strip pump, (no regulator 110 GPH?) and it is plenty.
Same as any Carter/Edelbrock/Holley
If you feel you need more, the upgrade 130 GPH, or a CV Products Speedway type pump will get r dun.
I do run a roller tip pump pushrod, just 'cause it's really cool.
I just never felt that using a huge fuel pump to connect to a spring and ball sitting on a .135" orifice made any sense.
A by-pass style regulator setup after the carb inlets might make sense.
I will NEVER, EVER be caught with an electric fuel pump on anything I own, other than the daily driver fuel injections.
I have seen races lost and oil pans crushed from a pump failure, or failure of the driver to turn it on.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
