Old 11-18-2008, 09:23 AM   #1
bobby
bobby's Avatar
Default Re: 8.5" GM Ten Bolt
I have a 8.5 out of a 73 Cutlass that I cut down to fit my 68 Firebird. These have factory press on bearings. No c-clips. I think that most 73-77 cutlasses and regals had this type of rear end. So if you are cutting, go with one of these and eliminate the c-clip eliminators and bastardizing (new word of the day) the rearend.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 11-18-2008, 06:42 PM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
U sure thats the same diff as the GM 8.5? The only rear that I know of that had pressed on bearings was a BOP 8.2. I know theres a difference for sure and parts availability is nill.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 11-19-2008, 02:38 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
the 8.2 died in 71...a 71 nova could have either an 82. or 8.5. Tod where you located? I have an 8.5 housing out of a 73 nova that will fit. if ya live close to Ohio I'll take $20 bucks for it...I think I have the axles too.
Old 06-03-2009, 08:45 PM   #4
Jesse Knapp
I have a 71 Nova with a 10 bolt. What do I look for to know if I have the large or small one? Is it maybe ring gear diameter? I knew this a long time ago but can't remember now. My thoughts were to just buy a complete 12 bolt from Strange, but it sounds like the big 10 bolt is plenty stout. Car came with a 307 and a glide. Still has the glide in it. I'm betting it's the small one.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 06-04-2009, 07:41 AM   #5
Jesse Knapp
I have a horrible memory! I just this morning remember something about the ring gear bolts are larger on the 8.5. Is this how one tells and, if so, what is the size comparison?
Old 06-04-2009, 08:45 AM   #6
skooter
http://www.novaresource.org/axle.htm
skooter is offline   Reply With Quote
Old 06-04-2009, 09:06 AM   #7
bobby
bobby's Avatar
Not sure about the 8.2, but the 8.5 has 7/16 bolts. The 12 bolt has 3/8 bolts.
Dont' worry about the memory, you probably forgot more than most people will ever know.
Old 06-04-2009, 03:53 PM   #8
Jesse Knapp
I am almost sure the ring gear bolts are larger on the 8.5. Thanks for posting the website address.
Old 11-19-2008, 08:27 AM   #9
bobby
bobby's Avatar
YES, it is. the only difference is that they have press on axle bearings. I have put 77 Camaro guts inside of one, if that says anything.
Old 05-30-2009, 09:22 AM   #10
Nitroman
Nitroman's Avatar
Does this particular diff have provisions for a torque arm ?? And do you still have it ?
Nitroman is offline   Reply With Quote
