#1 | |
Thats the famous "Green Weenie", The "Green Weenie" is a 9 second Chevelle. Oh, and the "Green Weenie" doesnt have a transbrake in it either, its a street car |
Liked 7,925 Times in 1,760 Posts
Mark, I think that the lower front pivot is what Tech has a problem with. What I have a problem with is why did they allow it for X number of years and then decide to not like it?
Liked 1,953 Times in 439 Posts
Because someone whined, I'm sure. The right person whined, more than likely.
Alan Roehrich 212A G/S |
#4 | |
Liked 19 Times in 4 Posts
Looks like the green weenie could use alfs front end kit .
What does the kit consist of, is it readily available and how much is it?
'67 Camaro 1.25 5.77 @ 118 |
ball joints custom,tie bars and bull nose afcos.
Are they tall ball joints? What are tie bars? I agree that it needs the bull nose afcos, 1925lbs crashing back down on my KONI's aint cuttin it.
*** 72 Malibu *** 1.329-3.99-6.28@106.71-9.98@131 best 60ft to date-1.2997 |
Liked 3 Times in 1 Post
72 malibu that is one bad street car. It is still not a stocker. The A body is one of the toughest stocker to run for two reasons, one is the rear suspension and the other is that the motors are some ot the most powerful in stock. Traction is the issue with 9 inch tires. The 1970 454 is so powerful, I elected to stay with a L78 402 in my stocker.
Alf builds one system that works with the high power A bodies front and rear suspension. It really works. The A body twist is eliminated. The cars hook in most car washes. His front end kit makes the car faster. On the launch, the front tires don't look like a duck and scrub off speed when they land. An A body has the upper arms tilted backwards for anti dive. The front is up in the air at the top end catching air. His system takes out the anti dive and increases the aero dynamics. When I changed to his new system last year, I gained 2.5 miles per hour in the traps. I have run a rear Weibe system since I started running my A body 6 years ago. The only reason to not buy one is that you want to have the pride that I designed my own system or I don't have the money to buy a complete system. I just figured how many years can I race? I want my car to run. I don't need to reinvent the wheel. He builds a proven system. If you ever get to spend time with him, he is as straight a person that you will find. He will help you at his own expense. What a great guy. Rick Kagawa 708 C/SA http://www.dragracecentral.com/DRCPh...r=100#indextop |
I have the complete Alf Wiebe system on my Chevelle. It is the original type that Alf built.
I just got word from NHRA that I will no longer be able to run my car after April 30, 2009 with this setup. I talked to Alf and He said that He is in the process of building a new rear suspension kit that will be legal in A body cars. Why are Cal-Trac bars legal? They adjust the pinion angle on leaf spring cars, no??? This is a little confusing to me. Craig B/SA Division 6 |
