Old 06-24-2008, 08:18 PM   #1
FLOYD RUSSO JR
Talking Re: 30x9x15 Hoosier Radials psi?
coach i have ran mine as low as 15--16psi i have a 01 pontiac a-sa,b-sa stocker!!!!!! boo-boo c-ya!!!!!!!
FLOYD RUSSO JR is offline   Reply With Quote
Old 06-24-2008, 10:53 PM   #2
Liked 1,784 Times in 407 Posts
Default Re: 30x9x15 Hoosier Radials psi?
I'd have to look at the log books, but I'm pretty sure we run about 24 psi. We've only had trouble hooking on the worst tracks, under bad conditions. And it's a 9 second Stocker in good air. It hooks well even at AA/SA weight.
Old 06-24-2008, 11:30 PM   #3
Grant Eldridge
Grant Eldridge's Avatar
Coach, we had a lot of trouble around 16-17 lbs with these tires, inconsistent. Tried many shocks, bar setups, everything. Finally raised the pressure in increments to 21 lbs. and never failed to hook since. This was a '69 Nova bb E/SA 3570lbs. and we ran this tire on a 10" rim.
Grant Eldridge is offline   Reply With Quote
Old 06-24-2008, 11:41 PM   #4
MHoward
try running them around 24-26 anything below 20 in a 3500 lb. car you will spin on a marginal track.
MHoward is offline   Reply With Quote
Old 06-25-2008, 12:10 AM   #5
Dave Goob Cook
Dave Goob Cook's Avatar
I've had two sets of Hoosier 9x30's, and have always run Goodyears since. Had no wear or consistency from the Hoosiers.
15 1/2 psi minimum to 16 1/2 psi maximum on my 3250# ride at mid 10's.
But, I'm a bracket racer.
I've found that the Goodyear D-4A is best all around for hot to cool tracks, with a very light burnout on hot (115*+) tracks. They do make better compounds for very hot track conditions.
Been running them since '01 or so?
There are usually 8 compounds available in Goodyear 9x30's
Dave Goob Cook is offline   Reply With Quote
