Old 05-10-2025, 08:39 AM   #1
TERRY HEMBREE
Liked 20 Times in 7 Posts
Default Fuel Factory
Anyone tried F8? Pros or cons?
TERRY HEMBREE is offline   Reply With Quote
Old 05-10-2025, 12:17 PM   #2
SDmopar
Liked 209 Times in 50 Posts
Default Re: Fuel Factory
Pros
Price
Con
Availability (price difference makes it easier to stock up.)
I?ll update report when I make it to the track.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is online now   Reply With Quote
Old 05-10-2025, 01:36 PM   #3
Stk4996
Liked 10 Times in 4 Posts
I dynoed with C11 & F8 they made the same power & torque. And as stated above the price is lot more racer friendly than c11.
Stk4996 is offline   Reply With Quote
Old 05-10-2025, 11:11 PM   #4
jeff_kovalik
jeff_kovalik's Avatar
Liked 186 Times in 30 Posts
I tried to support them, but failed fuel check twice, and others have often as well. Class racing is hard enough, and the risk of losing a qualifying run and the stress/debacle of switching fuels isn?t worth it.
Had to go back to VP.
jeff_kovalik is offline   Reply With Quote
Old 05-11-2025, 09:50 PM   #5
mike britt
Liked 66 Times in 31 Posts
I started running it late part of last year and haven't had any problems with fuel check. I have a dealer nearby, so it's easy to get for me.
mike britt is offline   Reply With Quote
Old 05-12-2025, 11:27 AM   #6
JP1738
JP1738's Avatar
Liked 1,228 Times in 345 Posts
I see a lot of class racers either sticking with VP exclusively or trying fuel factory stuff. I'm sure it's not true but it feels like I'm the only one running Sonoco. I've always run the Blue variety and never had problems. Is there a reason more class racers don't use it? I can usually buy it for around $10/gal so I know it's cheaper than VP, not sure on FF.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 05-12-2025, 06:56 PM   #7
TERRY HEMBREE
I also run the blue but it is nowhere to be found close to me since the main Georgia distributor went away a few years ago. Always got it at nationals and BG but no more nationals now. I found a FF source but since I started this thread I got phone call about another source for blue so problem solved. Thanks for all the comments.
Old 05-12-2025, 07:18 PM   #8
Liked 1,874 Times in 422 Posts
For us, in a Stock 427/425, and a Super Stock 396/375, Sonoco was slower, down about 10 on HP, than C12, and I made the most power on C14+.
The main cimplaint with C12 is that it sometimes didn't pass fuel check, even from a fresh, just opened VP drum on their trailer. NHRA would always "adjust", however it was a hassle, and sometimes they wouldn't re-instate a qualifying shot.
A lower compression and/or smaller engine might not care.
Old 05-12-2025, 08:35 PM   #9
SS3860
Liked 170 Times in 56 Posts
Terry, I also use Sunoco Blue, let me know if I can help get some for you at Bowling Green.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 05-14-2025, 11:13 AM   #10
BZenzen
BZenzen's Avatar
Liked 472 Times in 82 Posts
We made our first 14 runs on F8 after switching from C11.
Price point with the F8 is easier on the wallet versus VP fuel. Fuel Factory is continuing to grow it's networks of dealers across the US, so the availability is getting better for more racers to get their hands on the fuel.
We did notice more top end power in our combo (327 275hp SS Combo with a Q Jet). Engine builders around here that Dyno'd it versus VP did notice some HP gains in certain combos as well.
Brian Zenzen
SS 5404
STK 5401
BZenzen is offline   Reply With Quote
