Old 03-08-2024, 08:46 AM   #11
curtis reed
Liked 127 Times in 61 Posts
Default Re: water pump drive vs electric pump
Originally Posted by 68Coupe View Post
Curtis how much are those motors that you sell
I think they are around $97. I would have to double check with the sales guys. I run our manufacturing facility and don't deal with the retail side. They are much better than the little 2 post motors though, in power and rpm.
Curtis
curtis reed is offline   Reply With Quote
Old 03-08-2024, 12:35 PM   #12
When I used the belt drive pumps, I would order the larger overdrive pulley.
Moroso or Mr. G ?
Turns the pump faster. Of course it uses up more juice.
Old 03-08-2024, 01:53 PM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I did as well
Old 03-09-2024, 12:04 PM   #14
Steve Grady
Steve Grady's Avatar
Liked 181 Times in 58 Posts
The Moroso part number 97252 is the larger drive pulley for the electric motor that is 28% faster.
Moroso or Mr. G ?
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 03-09-2024, 01:56 PM   #15
Dave Gantz
Liked 251 Times in 125 Posts
Smile Re: water pump drive vs electric pump
Drag racers... can't leave anything alone!!!! lol!
Old 03-11-2024, 03:53 AM   #16
GTX JOHN
14 teeth opposed to 10 as I seem to recall.
John Irving
741 Stock
741 Super Stock
Old 03-11-2024, 02:37 PM   #17
goinbroke2
Liked 405 Times in 158 Posts
Thanks for all the replies guys, I'm getting a pump drive from a local S/SS racer. Maybe down the road I'll try an electric pump but I still think it would look silly having a "race" electric pump on a 302 2bbl, LOL!!!!
Old 03-15-2024, 07:58 PM   #18
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Following up Curtis's post above regarding those good quality 4 post drive motors. Installed one, and it works great. It's about 6 oz. heavier than the current replacement Moroso motor. In my application with a well used water pump, overdrive pulley, and "dry", the 4 post unit draws about 3 Amps vs. the Moroso's 3.5 Amps (roughly 3 yrs. of use).
T Ames is offline   Reply With Quote
Old 03-26-2024, 10:34 AM   #19
novassdude
Liked 136 Times in 49 Posts
I don't know if any one is using them on class cars but I am switching to a Davies Craig remote mount water pump. A huge weight savings and they cool some very high HP drag and drive cars.
novassdude is offline   Reply With Quote
Old 03-26-2024, 11:39 AM   #20
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
one good thing about an electric water pump drive is that you can bolt on a light weight plastic fan blade on it and get both with one circuit.
