Old 05-17-2008, 07:47 PM   #12
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: need a little help...
two years ago we had a ford v6 in the shop,same deal intake tuliped also did the exhaust valve in as well ,found that it had a bad crank sensor caused timing to retard and they ran it hot ,check the timing,maybe the bump in compression was enough to do it in,check the distibutor make sure your pickup is phased with rotor, this will raise combustion temp,whats your ignition set up gmonde
