Yes the valve lash would go to zero.
After, i put new rings, bearing and gaskets thats when the problem occurred. I use a .070 wide valve seat width. But the old valves were the same way. I changed to a thinner head gasket to try and get a llittle more compression. I had always used manley valves in the past. Never had a problem with them. These valves were a no name brand. I am thinking that I am running to lean, the exhaust gas temperature is 1400 deg. in high gear. I run 32 degrees total timing, that seems to be the limit with my combination. It runs slower e.t and mph with more timing. |
Go back either to a Manley or Ferrea valve. Low cost valves made overseas tend to be softer. I have checked lower cost valves for hardness in the past, and there is a difference. Quality control for materials and processing is not the same with overseas made valves that are mass produced. They cannot sustain lean conditions and the higher spring pressures used in racing.
Liked 165 Times in 59 Posts
two years ago we had a ford v6 in the shop,same deal intake tuliped also did the exhaust valve in as well ,found that it had a bad crank sensor caused timing to retard and they ran it hot ,check the timing,maybe the bump in compression was enough to do it in,check the distibutor make sure your pickup is phased with rotor, this will raise combustion temp,whats your ignition set up gmonde
I run msd ignition, dist.,6al-2 box, blaster coil. 16 deg. intial, all in at 2750rpm and 32 degrees total.
Count your lucky stars the head and stem are still intact!
Jeff Lee 7494 D/S '70 AMX |
