Old 11-15-2023, 10:57 AM   #1
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 228 Times in 98 Posts
Default Re: « WAGON OF STEEL » 1000 feet nose diving technic.
Originally Posted by curtis reed View Post
I have always believed that it would benefit many class racers to bracket race when they aren't racing their class car just to get used to things like this.
I used to think this also, and would see some good class racers doing just that. But if you have a hard running car, there are a lot of parts with limited life spans. The cost per run gets pretty high. So I understand why many would not want to do it.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 11-15-2023, 12:51 PM   #2
Adub464Q
Adub464Q's Avatar
Liked 482 Times in 92 Posts
Not subscribing or unsubscribing to conspiracy theories....however, I would like some opinions on this.
WIth a grid, you can set a safety RPM limit to come on at a pre-determined time after a trigger point. For instance in my super class cars, I have this set at 12 seconds after the trigger point (transbrake released). It is set at 12 seconds, as this is SC and SG cars therefore it will be in shutdown. This is in case there is an issue in the shutdown area, the ignition box will only allow the engine to go to 3000 rpm in my cars case.
If you were to set this at 9 seconds (on an 11 second car), would this be considered a downtrack rev limiter or is this a safety switch?
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 11-15-2023, 01:28 PM   #3
Lenny5160_v2
That's an illegal downtrack rev limiter, IMO.
Tony Leonard
S/ST 56
S/C 53
Old 11-15-2023, 01:38 PM   #4
bigshow2966
Liked 181 Times in 56 Posts
Downtrack rev limiter would be my guess.
The last race I was with Mike Jeffrey at Tri-State he had not changed rear gears from Denver. He didn't think it would leg through, but 1st qualifier he went .99X under. He decided to run to the 1000 foot mark and let off. He made it 4 rounds that way and avoided a hit. It wasn't scrubbing a whole lot of ET off either.
bigshow2966 is offline   Reply With Quote
Old 11-15-2023, 04:50 PM   #5
Ellis V Buth
Liked 420 Times in 73 Posts
1000' lift and coast doesn't kill near as much as some would think. It all depends on momentum and whatnot but I've found in some of my bracket cars it can be as little as .15 or as much as .30 depending on speed and weight and conditions.
Ellis V Buth is offline   Reply With Quote
Old 11-15-2023, 08:43 PM   #6
jim reynolds
Liked 24 Times in 11 Posts
Not hard to do legally...bitd 80's IHRA super stock, we had to dial either index or record and in bad air i just flat could not run the record. SOooo i would pick 1 telephone pole to run to and go to neutral and back into the index. Worked sometimes lol !
jim reynolds is offline   Reply With Quote
Old 11-15-2023, 08:47 PM   #7
Jim Caughlin
Liked 806 Times in 246 Posts
Can't speak for other combos but letting off the throttle and not hitting the brakes doesn't really kill a lot of MPH in my car.
Jim Caughlin is online now   Reply With Quote
