Old 07-26-2023, 08:23 PM   #1
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Flat tappet lifter failure
Curious how many have had this problem regardless of reasoning in last 5 years or so.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 07-27-2023, 01:18 AM   #2
GTX JOHN
Liked 2,490 Times in 700 Posts
Default Re: Flat tappet lifter failure
My boy has had issues that have cost engines while
running the expensive billet stuff.
John Irving
741 Stock
741 Super Stock
Old 07-27-2023, 09:34 AM   #3
Run to Rund
Liked 54 Times in 27 Posts
Spring pressure and lifter diameter are factors as well. Stock lifters are good at 380 lb. open and .921" diameter. 500-550 lb. open are another story.
Old 07-27-2023, 08:51 PM   #4
Gmirza
Liked 253 Times in 95 Posts
I lost one cam lobe, I noticed it after about 100 runs. I’m not sure when it went away. Most likely caused by lack of oiling at low rpm. From what I’ve been told the tool steel lifter, cast cam combination is only good for maybe 200 runs if you’re lucky. Go fast stuff can be a P.I.T.A.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 07-27-2023, 09:30 PM   #5
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Originally Posted by Gmirza View Post
I lost one cam lobe, I noticed it after about 100 runs. I’m not sure when it went away. Most likely caused by lack of oiling at low rpm. From what I’ve been told the tool steel lifter, cast cam combination is only good for maybe 200 runs if you’re lucky. Go fast stuff can a P.I.T.A.
Hi George, do you know what your spring pressures were open and closed.
Paul Precht is online now   Reply With Quote
Old 07-28-2023, 04:06 PM   #6
Demon340
Liked 108 Times in 29 Posts
Lost a Tool Steel lifter after 6 runs..
Demon340 is offline   Reply With Quote
Old 07-28-2023, 07:46 PM   #7
Gmirza
Hi Paul,
I’m not sure. I didn’t check them.
George Mirza
D/SA 1236
‘71 Duster 340
Old 07-29-2023, 12:25 PM   #8
Bench Racer
Liked 99 Times in 21 Posts
Terry you have a PM
Bench Racer is offline   Reply With Quote
Old 10-05-2023, 08:11 AM   #9
Terry Cain
Terry Cain's Avatar
https://rehermorrison.com/tech-talk-...-flat-tappets/
Terry Cain ???? STK
Old 10-05-2023, 09:09 AM   #10
Billy Nees
Liked 7,860 Times in 1,750 Posts
Originally Posted by Terry Cain View Post
What's your point. If you want to use a roller cam then either run SS or build a newer Corvette Stocker!
Billy Nees 1188 STK, SS
