Old 06-27-2023, 10:37 AM   #3
Steve Grady
Steve Grady's Avatar
Liked 122 Times in 42 Posts
Default Re: Cam Dynamics info needed
Based on the numbers Lobe separation should be 106 degrees, And a small base circle .900. for extra cam clearance to rotating assembly. Higher ratio rockers would give you more lift if needed.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
