-   Stock and Super Stock Tech (https://classracer.com/classforum/forumdisplay.php?f=4)
-   -   Cam Dynamics info needed (https://classracer.com/classforum/showthread.php?t=85152)
bkeesee 06-26-2023 04:20 PM
Looking for any info on an old sbc Cam Dynamics roller cam I acquired in old engine. This is what I find on front of cam: Also attached a picture.
CD 310
310 - 06
900 BC
7R KK775
older racer 06-26-2023 05:07 PM
Re: Cam Dynamics info needed
hello, have an old catalog of cam dynamics cams from what i gather, book ,shows, R310, 310-06 270 dur @ .050 .600 lift, ,030 lash,its for oval track racing hope thos helps
Steve Grady 06-27-2023 10:37 AM
Based on the numbers Lobe separation should be 106 degrees, And a small base circle .900. for extra cam clearance to rotating assembly. Higher ratio rockers would give you more lift if needed.
bkeesee 07-01-2023 11:04 AM
Thanks for the info Gentlemen .
Any ideas on what lobe center it should be installed at?
DeuceCoupe 07-03-2023 08:29 PM
Never any single answer as to lobe center or ICL Intake Center Line.
Rules of Thumb if any:
Street car, install it advanced 4 degrees
So if LSA=106, use ICL=102
Race, install it straight up 0 advance
So if LSA=106 use ICL=106
From there it depends on the car, weight, gear, airflow, cam size.
That's a pretty big cam so I'd guess ICL=102 but really just have to try it.
