Liked 987 Times in 271 Posts
I decided to make a one midplate that incorporates the factory plate which serves as a locator for the starter, and the midplate You were right, it wasn't .060, its .090, I use a 5/8 chromoly tube limiter and after almost 200 runs, nothing has bent. I still use the trans mount also,
Duane Hoven 1342 SS/GT Last edited by 1347; 02-02-2023 at 11:18 PM. |
Liked 78 Times in 42 Posts
So the tubing you used as a limiter where did you place them? Thanks for the advice as what to do.
[QUOTE=Kirk Morgan;675238]So the tubing you used as a limiter where did you place them? Thanks for the advice as what to do.
I made a bracket that bolts to the original passenger side motor mount bolt holes in the block. The tubing attaches to that with a heim joint, and the other end attaches to the crossmember my strut rods attach to.
Duane Hoven 1342 SS/GT |
