#1 | |
Liked 183 Times in 48 Posts
SS/BS 1921 |
Liked 345 Times in 149 Posts
Rotational or forward/aft bending? Anything that leaves hard should have travel limiters that keep engine/transmission from moving in any direction.
Phil Molski PMR Performance S/C 1623 |
Liked 78 Times in 42 Posts
I was thinking about leaving the transmission cross member in to control the forward and rear movement of the engine. I have seen some cars with a strut mounted to the motor plate also.
Liked 306 Times in 172 Posts
Add an engine limiter. You can't rely on the crossmember to control the movement.
#5 | |
The stock mounts are forgiving, whereas tail shaft housings can and do break under heavy load especially when mounted solid to the crossmember.
SS/BS 1921 |
Liked 1,538 Times in 575 Posts
When I built my former 1994 Mustang Comp Super Modified car, I used the centered engine and mid-plate. As Steve said, not only for header clearance but also because the torsional loads have an effect on the suspension settings and adjustment when the engine is not centered.
For a transmission mount, I used a Polyurethane mount. |
#7 | |
Here are photos of the bends.
SS/BS 1921 |
#8 | |
Somehow, it's allowing the engine/trans to still move. Had a dragster once that would bend the plate with only 2 inches between the block and side rail - the limiters were on the frame rail which would move on launch. Moved the limiters to a tubing junction and the movement went away. Can't allow movement if it's placed correctly. Chassis twist, or flex, may be doing it. That's kinda ugly.
#9 | |
I do a lot of welding and fabrication. If the steel was sourced offshore, then it's not ideal. That's not to say that domestic steel wouldn't have bent, but I doubt it would have to the degree seen in the photos. All of the offshore steel that I have used is substandard at best. You can tell immediately when you hit it with the tig torch.
SS/BS 1921 |
#10 | |
Can't argue about quality of the steel, I agree. But, if the front (with any material) isn't bending, then it leads me to wonder if the rear is moving up or down (instead of fore and aft) on the hard landings - crossmember possibly flexing would sort of "pivot" on the front support and help to bend the midplate? Tossing ideas out here because if nothing is moving, nothing can bend, I don't care what material it's constructed from.
