Old 04-06-2022, 11:57 AM   #1
Mike Mans
Liked 299 Times in 48 Posts
Default Re: accusump plumbing
Hey Larry - We use the kit from Moroso in the link below. It works really well! It shows that they are out of stock, but I would think a little Google searching may bring up whatever the source is for that solenoid and it's just a pipe nipple that connects it to the accumulator container too.
https://www.moroso.com/solenoid-valve23905/
Mike Mans is offline   Reply With Quote
Old 04-06-2022, 01:54 PM   #2
SSDiv6
Canton also makes several accumulator electric valves.
https://www.cantonracingproducts.com...or/valves.html
Old 04-06-2022, 02:14 PM   #3
Liked 10,926 Times in 2,257 Posts
Thanks to both of y’all.
Old 04-06-2022, 10:06 PM   #4
Frank Castros
Liked 2,765 Times in 978 Posts
I met Mike Canton back in the seventies when he worked for Dick Moroso, he's a very smart dude.
Old 04-08-2022, 12:39 AM   #5
CMcAllister
Liked 924 Times in 262 Posts
I use an electric valve mounted on the accusump. They replace the manual ball valve if that's what you are asking. One advantage is the electric valve will allow the can to charge when it is off but not allow oil to go back to the engine until it is turned on.
I use a dedicated switch to control the valve as desired.
Pre-oil the engine before cranking if it has been sitting overnight or longer. Turn it off once the engine is running to allow it to refill. Leave it off until I roll into the water. Turn it on at that point and leave it on until after making the turn off. Turn it off at that point and leave it refill the can while driving back to the trailer and back to the lanes.
Also useful for pre-oiling a fresh engine. Just have to fill, assemble and charge it, usually out of the car.
That was my routine.
CMcAllister is online now   Reply With Quote
Old 04-08-2022, 06:59 AM   #6
hrs1326
Liked 19 Times in 10 Posts
al always you guys are very helpful, I appreciate the info
race on!
hrs1326 is offline   Reply With Quote
Old 04-08-2022, 08:51 AM   #7
Signman
Liked 269 Times in 99 Posts
Have one of the Moroso valves will part with.
PM with a fair offer
