Old 01-02-2022, 11:57 PM   #1
Tim Jonsson
Default 428 Shelby SS
I'm trying to determine what the rules are pertaining to a 1967 Shelby 428 with dual fours and flattop pistons combo for SS.
new engine is using the Edelbrock heads, BBM block, Winberg crank, 55mm LSM cam, Manley rods, Gibtec pistons etc.
is there any difference in piston configuration required by NHRA from 67 to 70 for example,.
I was previously running the CJ 428 iron head combo in a 1970 Cougar in SS/HA
Thanks
Tim Jonsson is offline   Reply With Quote
Old 01-03-2022, 10:20 AM   #2
SSDiv6
Liked 1,593 Times in 583 Posts
Default Re: 428 Shelby SS
Thanks
You have to look at the NHRA Accepted Products List for the appropriate parts. There is no NHRA approved Winberg crankshaft for the 427 FE and there is no Manley approved connecting rods for the Ford FE engines either.
The pistons have the same compression height and are flat with notches from 1967 to 1969. The only approved Edelbrock cylinder heads are P/N 60058 (Stock and Super Stock) and P/N 61857 (Super Stock only).
Old 01-04-2022, 03:23 PM   #3
Tim Jonsson
Hi Div. 6
good to know
yes I have the 60058 Edelbrock heads with the NHRA emblem cut into them, prepared by Clairidge racing heads to the NHRA port volume specs as listed on the site.
I had another set of the 60058 in the boxes which I sold and now regret, maybe I'll try to find some pro-port versions.
wondering if anyone has run the 2 x 4 setup, i'll contact NHRA as well
Thanks
Old 01-05-2022, 12:32 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Wait! This is a SS combination. "Flat w/notches" is the only configuration required.
Old 01-05-2022, 12:43 PM   #5
SSDiv6
Missed that!
Old 01-05-2022, 08:05 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
Molnar has a rod that is "legal" that will keep it alive above 6500 RPM.
Probably needs to do the BB Chevy rod bearing size modification too.
428's had a lot of issues with RPM until Blair Patrick got the 361 truck crank and Chevy Bearing and Crower Rod combination approved.
Adger Smith (Former SS)
Old 01-06-2022, 01:45 AM   #7
Mike Gray
Mike Gray's Avatar
Liked 692 Times in 200 Posts
I have a set of those Crower rods in my 428, be prepared to break open the piggy bank.
Mike Gray is online now   Reply With Quote
