Old 09-13-2021, 01:39 PM   #1
Grover
Liked 6 Times in 4 Posts
Default O2 Sensor Location
This has probably been asked, but couldn't find it, so will ask. How far away from the primaries in the collector should the O2 sensor be placed? This is for a 4th Gen F body LT1 stock eliminator. Using a Holley HP system.
Grover is offline   Reply With Quote
Old 09-15-2021, 02:46 AM   #2
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: O2 Sensor Location
I moved mine from the collector and put it about 10” away from the head in a primary tube. Works much better than in a collector. People will argue “but that’s only measuring one cylinder instead of the average. What if that cylinder has a problem?” To me it doesn’t matter in that regard. No matter where it’s located and you have a bad cylinder it’s still going to be messed up.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 09-15-2021, 06:24 AM   #3
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
I was advised 9" from the header flanges. One in each primary, so you can move the 02's around.
427FE is offline   Reply With Quote
Old 09-15-2021, 12:19 PM   #4
KRatcliff
Liked 534 Times in 143 Posts
A good way to mark where to place the O2 once you measure down from the flange is to use a spark plug. That will give you a good idea where on the tube to get enough clearance for the O2 and wire.
KRatcliff is offline   Reply With Quote
Old 09-15-2021, 01:03 PM   #5
J.R. Haddad
Liked 1,470 Times in 308 Posts
Cancelled.
J.R. Haddad is offline   Reply With Quote
Old 09-15-2021, 03:48 PM   #6
SSDiv6
Liked 1,600 Times in 583 Posts
Talking Re: O2 Sensor Location
Kyle,
Since you are a Texan, do you use a 5/8" Short Reach spark plug or a Long Reach, 13/16" spark plug??? :
Old 09-15-2021, 03:52 PM   #7
KRatcliff
Kyle,
Everything is bigger in Texas. 😂
