Is anyone running a Racepak driveline sensor on the GM 12-bolt? Looking for some ideas for the mounting bracket
Liked 590 Times in 163 Posts
About 6" long piece of angle aluminum stock with 2 holes through the web of the 12 bolt to mount it. A slight twist put into it with and pair of adjustable wrenches.
Liked 57 Times in 24 Posts
I was going to mount on the yoke but would had to remove
And machine a surface for the ring I just mounted the ring on the Tran yoke and the pickup Off the tail shaft web. Works good. I running a metric 200 trans David |
Liked 6 Times in 2 Posts
I built a mount, drilled holes in the webing and mounted there. I still have template I can post tomorrow
Mike Semeniuk 632 GTMA |
Liked 327 Times in 87 Posts
Liked 132 Times in 27 Posts
Liked 125 Times in 59 Posts
This is on a Dana but the same idea I applied on my 12 bolt. Just made the aluminum piece a little cleaner. That one we made in a hurry and is the only pic I have. Then a small angle bolted on for the sensor.
Liked 535 Times in 110 Posts
I've made a couple, one for my son's and for my own car, both for 12-bolts. Similar to what Rich B. above says, I used a piece of 1/4" thick x 1" wide 90° angle aluminum x about 6" long. Drilled a pair of 1/4" holes through the webs for mounting. Mine are certainly not CNC quality but I think as long as the sensor winds up .050"-.100" from the split collar, you're alright.
Jim Kaekel 3836 STK |
