Old 02-16-2021, 01:08 PM   #1
John Dinkel
Liked 263 Times in 68 Posts
Default Optima Battery
Which Optima battery for race car Red or Yellow?
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 02-16-2021, 01:23 PM   #2
Dan Walcott
Liked 92 Times in 26 Posts
Default Re: Optima Battery
Yellow Top / with Optima charger
Dan Walcott is offline   Reply With Quote
Old 02-16-2021, 01:40 PM   #3
John Dinkel
Thanks Dan
Old 02-16-2021, 02:15 PM   #4
GTX JOHN
Hum..............We run exclusively red tops.
All our cars including both our Superstockers and
our Dragster run functional Alternators!
I do run a Yellow Top on our winch.
Please correct me if I am all WET = Not an electrical expert!
John Irving
741 Stock
741 Super Stock
Old 02-16-2021, 03:04 PM   #5
Jeff Stout
Liked 706 Times in 283 Posts
Red Tops in Stocker and bracket car. Bracket car was 6 years old and just replaced in December. Alternator on car also. I have been using solar battery charger when time allows. It is slow but works until eliminations then I go to generator.
Old 02-16-2021, 03:09 PM   #6
GUMP
Liked 2,354 Times in 554 Posts
I have red tops in all of my cars. They all have functioning alternators.
Old 02-16-2021, 03:30 PM   #7
Phil Veldheer Racing
Liked 26 Times in 8 Posts
I've used both and the yellow top with the OPTIMA charger seems to spin my engines at a higher rpm. I do have an alternator also. I will convert all my cars to yellow top from red.
Phil Veldheer Racing is offline   Reply With Quote
Old 02-16-2021, 03:44 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
The yellow top Optima is a deep cycle battery. The red top is a starting battery. You should be using the red top in a race car. Typically a deep cycle battery takes longer to charge and likes a low amp charge. They are best for RV and trolling motor type applications
Mike Pearson 2485 SS
Old 02-16-2021, 04:26 PM   #9
Jeff Stout
This was my understanding also
Old 02-16-2021, 05:02 PM   #10
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Red Tops in the Challenger Stocker.
