Liked 263 Times in 68 Posts
Which Optima battery for race car Red or Yellow?
John Dinkel 3295 STK |
Liked 92 Times in 26 Posts
Yellow Top / with Optima charger
Thanks Dan
Hum..............We run exclusively red tops.
All our cars including both our Superstockers and our Dragster run functional Alternators! I do run a Yellow Top on our winch. Please correct me if I am all WET = Not an electrical expert!
Liked 706 Times in 283 Posts
Red Tops in Stocker and bracket car. Bracket car was 6 years old and just replaced in December. Alternator on car also. I have been using solar battery charger when time allows. It is slow but works until eliminations then I go to generator.
Liked 2,354 Times in 554 Posts
I have red tops in all of my cars. They all have functioning alternators.
Liked 26 Times in 8 Posts
I've used both and the yellow top with the OPTIMA charger seems to spin my engines at a higher rpm. I do have an alternator also. I will convert all my cars to yellow top from red.
Liked 1,943 Times in 584 Posts
The yellow top Optima is a deep cycle battery. The red top is a starting battery. You should be using the red top in a race car. Typically a deep cycle battery takes longer to charge and likes a low amp charge. They are best for RV and trolling motor type applications
Mike Pearson 2485 SS |
#9 | |
Liked 693 Times in 205 Posts
Red Tops in the Challenger Stocker.
