Old 12-17-2020, 11:30 AM   #1
3 window
Liked 3 Times in 2 Posts
Default Rearend height vs weight bias
Hello all, I have a couple quick questions, how much would a 2” lowering block between my rearend housing and the leaf spring affect my weight bias? Would it affect it much or no? Also any significant affect on the Caltrac operation? Thanks.
3 window is offline   Reply With Quote
Old 12-17-2020, 01:36 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Rearend height vs weight bias
Can't really say but 2 inches sounds like a lot. Calvert sells 1 inch blocks and plus or minus 1 inch split mono springs. People on Yellow Bullet say they broke aluminum blocks, so be careful.
Dale Shearon
68 Mustang 6394
Old 12-17-2020, 02:52 PM   #3
SSDiv6
If possible, you should try to scale the car first and then talk to Calvert. If the car doesn't have any issues launching and you just want to lower the car for looks, it will change the CG and dynamics of the car.
