Old 12-12-2020, 11:49 AM   #12
Spyphish
Liked 679 Times in 180 Posts
Default Re: Listen to a story 'bout man named Phish
All rod and main bearings had a 100thou spacer and one rod had one little brass shim left. She is wore out. Babbit still there so may mic and polish crank, repour rods etc and buy a shim kit from The Filling Station, clean it up, hone, ring. Chiity Chitty Bang Bang
I learned the cranks bend easy so they suggest spin it in a lathe and check runout. If bent, pry it back straight and roll on. Uncle Jed
ID:	56471   Click image for larger version
ID:	56470   Click image for larger version
