has anyone used rim screws with these slicks? I Know it says do not use rim screws but...
Liked 431 Times in 224 Posts
20-25 years ago I was putting screws in Hoosier radials with no problems.
When I went from 8" wheels to 10" wheels I didn't want to drill them, so I stopped using screws. Haven't noticed any reason to go back to it.
S/ST 51 S/C 53 |
Liked 163 Times in 53 Posts
I raced at a local heads up race this past weekend and saw many cars running this tire and no screws....
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 207 Times in 23 Posts
I run them on my DragnWagn NSS car....no screws....amazing tire.
Liked 805 Times in 341 Posts
Liked 6 Times in 2 Posts
I’m on my 3rd season with the 10.5x29.5 on a 3500lb nostalgia super stock chevelle on a 9.75 index it has 60 footed 1.31 with a 1.360 restrictor plate , I do not use screws but do use permatex hi tack on bead , be sure and do that the first set did not move on the wheels but 2nd set did so they was broke down and hi tack applied and no more slipping . I have seen pictures of radials used with screws with destroyed beads but no personal experience.
Liked 251 Times in 125 Posts
I would try it without screws, glues, or other tricks. If it works, you've eliminated more "stuff to be done". K.I.S.S.
Liked 348 Times in 152 Posts
Just make sure to use only water, not any kind of lube or soap when mounting.
Phil Molski PMR Performance S/C 1623 |
Liked 172 Times in 81 Posts
I was told by MT no screws with radials. I run 26 x 8 MT's, no screws, no problems, admittedly limited HP but 3500 lbs.
Jim Mantle V/SA 6632 |
Liked 345 Times in 149 Posts
Been running radials for 25+ years now. Clean the rim bead seat surface well, no lube and install dry.
Faster cars may want to install beadlocks, but I have been 1.12 60' without. Radial beads are not designed for screws. Friend and customer had a bead split around the circumference totally destroying the tire from rim screws. |
