Old 06-29-2020, 09:55 PM   #11
Al Wilson
Liked 109 Times in 38 Posts
Default Re: 727 Torqueflight question
Clean everything as best you can, then sprinkle some talcum powder around the suspect areas. The red fluid where leaking will really stand out.
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 06-30-2020, 09:04 AM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
This is a great idea ! We used to use spray foot powder just because of the ease of appying it .
ss3011 is online now   Reply With Quote
Old 06-30-2020, 09:36 AM   #13
Kevin Panzino
Kevin Panzino's Avatar
Liked 776 Times in 142 Posts
Ha, love it. Great idea, and not limited to trans fluid either. Excellent trick,
thanks !
Old 07-02-2020, 11:39 PM   #14
CMcAllister
Liked 920 Times in 259 Posts
There is a kickdown shaft, that the kickdown lever is attached to, that goes down through the center of the shift shaft. Has it's own little lip seal. They will leak as well.
Lots of little places to leak on those, especially an older unit. Some of them will have the cooler and/or converter drain back if it sets for awhile. When that occurs, the leaks show up
